golioth_client.h File Reference
#include <stdbool.h>
#include <stdint.h>
#include <stdlib.h>
#include "golioth_status.h"
#include "golioth_sys.h"
Data Structures
struct  golioth_response_t
 Response status and CoAP class/code. More...
struct  golioth_psk_credentials_t
struct  golioth_pki_credentials_t
struct  golioth_tls_credentials_t
 TLS Authentication Credentials. More...
struct  golioth_client_config_t
 Golioth client configuration, passed into golioth_client_create. More...
Typedefs
typedef void * golioth_client_t
 Opaque handle to the Golioth client. More...
typedef void(* golioth_client_event_cb_fn) (golioth_client_t client, golioth_client_event_t event, void *arg)
typedef void(* golioth_get_cb_fn) (golioth_client_t client, const golioth_response_t *response, const char *path, const uint8_t *payload, size_t payload_size, void *arg)
typedef void(* golioth_get_block_cb_fn) (golioth_client_t client, const golioth_response_t *response, const char *path, const uint8_t *payload, size_t payload_size, bool is_last, void *arg)
typedef void(* golioth_set_cb_fn) (golioth_client_t client, const golioth_response_t *response, const char *path, void *arg)
Enumerations
enum  golioth_client_event_t { GOLIOTH_CLIENT_EVENT_CONNECTED , GOLIOTH_CLIENT_EVENT_DISCONNECTED }
 Golioth client events. More...
enum  golioth_tls_auth_type_t { GOLIOTH_TLS_AUTH_TYPE_PSK , GOLIOTH_TLS_AUTH_TYPE_PKI }
 TLS authentication type. More...
Functions
golioth_client_t golioth_client_create (const golioth_client_config_t *config)
bool golioth_client_wait_for_connect (golioth_client_t client, int timeout_ms)
golioth_status_t golioth_client_start (golioth_client_t client)
golioth_status_t golioth_client_stop (golioth_client_t client)
void golioth_client_destroy (golioth_client_t client)
bool golioth_client_is_running (golioth_client_t client)
bool golioth_client_is_connected (golioth_client_t client)
void golioth_client_register_event_callback (golioth_client_t client, golioth_client_event_cb_fn callback, void *arg)
uint32_t golioth_client_num_items_in_request_queue (golioth_client_t client)
void golioth_client_set_packet_loss_percent (uint8_t percent)
bool golioth_client_has_allocation_leaks (void)
golioth_sys_thread_t golioth_client_get_thread (golioth_client_t client)
