Functions | |
int32_t | golioth_payload_as_int (const uint8_t *payload, size_t payload_size) |
float | golioth_payload_as_float (const uint8_t *payload, size_t payload_size) |
bool | golioth_payload_as_bool (const uint8_t *payload, size_t payload_size) |
bool | golioth_payload_is_null (const uint8_t *payload, size_t payload_size) |
golioth_status_t | golioth_lightdb_set_int_async (golioth_client_t client, const char *path, int32_t value, golioth_set_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_set_int_sync (golioth_client_t client, const char *path, int32_t value, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_set_bool_async (golioth_client_t client, const char *path, bool value, golioth_set_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_set_bool_sync (golioth_client_t client, const char *path, bool value, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_set_float_async (golioth_client_t client, const char *path, float value, golioth_set_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_set_float_sync (golioth_client_t client, const char *path, float value, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_set_string_async (golioth_client_t client, const char *path, const char *str, size_t str_len, golioth_set_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_set_string_sync (golioth_client_t client, const char *path, const char *str, size_t str_len, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_set_json_async (golioth_client_t client, const char *path, const char *json_str, size_t json_str_len, golioth_set_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_set_json_sync (golioth_client_t client, const char *path, const char *json_str, size_t json_str_len, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_get_async (golioth_client_t client, const char *path, golioth_get_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_get_int_sync (golioth_client_t client, const char *path, int32_t *value, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_get_bool_sync (golioth_client_t client, const char *path, bool *value, int32_t timeout_s) |
Similar to golioth_lightdb_get_int_sync, but for type bool. More... | |
golioth_status_t | golioth_lightdb_get_float_sync (golioth_client_t client, const char *path, float *value, int32_t timeout_s) |
Similar to golioth_lightdb_get_int_sync, but for type float. More... | |
golioth_status_t | golioth_lightdb_get_string_sync (golioth_client_t client, const char *path, char *strbuf, size_t strbuf_size, int32_t timeout_s) |
Similar to golioth_lightdb_get_int_sync, but for type string. More... | |
golioth_status_t | golioth_lightdb_get_json_sync (golioth_client_t client, const char *path, char *strbuf, size_t strbuf_size, int32_t timeout_s) |
Similar to golioth_lightdb_get_int_sync, but for string-encoded JSON objects. More... | |
golioth_status_t | golioth_lightdb_delete_async (golioth_client_t client, const char *path, golioth_set_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_delete_sync (golioth_client_t client, const char *path, int32_t timeout_s) |
golioth_status_t | golioth_lightdb_observe_async (golioth_client_t client, const char *path, golioth_get_cb_fn callback, void *callback_arg) |
golioth_status_t | golioth_lightdb_stream_set_int_async (golioth_client_t client, const char *path, int32_t value, golioth_set_cb_fn callback, void *callback_arg) |
Similar to golioth_lightdb_set_int_async, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_int_sync (golioth_client_t client, const char *path, int32_t value, int32_t timeout_s) |
Similar to golioth_lightdb_set_int_sync, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_bool_async (golioth_client_t client, const char *path, bool value, golioth_set_cb_fn callback, void *callback_arg) |
Similar to golioth_lightdb_set_bool_async, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_bool_sync (golioth_client_t client, const char *path, bool value, int32_t timeout_s) |
Similar to golioth_lightdb_set_bool_sync, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_float_async (golioth_client_t client, const char *path, float value, golioth_set_cb_fn callback, void *callback_arg) |
Similar to golioth_lightdb_set_float_async, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_float_sync (golioth_client_t client, const char *path, float value, int32_t timeout_s) |
Similar to golioth_lightdb_set_float_sync, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_string_async (golioth_client_t client, const char *path, const char *str, size_t str_len, golioth_set_cb_fn callback, void *callback_arg) |
Similar to golioth_lightdb_set_string_async, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_string_sync (golioth_client_t client, const char *path, const char *str, size_t str_len, int32_t timeout_s) |
Similar to golioth_lightdb_set_string_sync, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_json_async (golioth_client_t client, const char *path, const char *json_str, size_t json_str_len, golioth_set_cb_fn callback, void *callback_arg) |
Similar to golioth_lightdb_set_json_async, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_json_sync (golioth_client_t client, const char *path, const char *json_str, size_t json_str_len, int32_t timeout_s) |
Similar to golioth_lightdb_set_json_sync, but for LightDB stream. More... | |
golioth_status_t | golioth_lightdb_stream_set_cbor_async (golioth_client_t client, const char *path, const uint8_t *cbor_data, size_t cbor_data_len, golioth_set_cb_fn callback, void *callback_arg) |
Similar to golioth_lightdb_stream_set_json_async, but for CBOR. More... | |
golioth_status_t | golioth_lightdb_stream_set_cbor_sync (golioth_client_t client, const char *path, const uint8_t *cbor_data, size_t cbor_data_len, int32_t timeout_s) |
Similar to golioth_lightdb_stream_set_json_sync, but for CBOR. More... | |
