Functions for converting JSON types into C types
◆ golioth_payload_as_bool()
| bool golioth_payload_as_bool |
const uint8_t * | payload, |
size_t | payload_size ) |
Convert raw byte payload into a bool
- Parameters
| payload | Pointer to payload data |
| payload_size | Size of payload, in bytes |
- Return values
| true | payload is exactly the string "true" |
| false | otherwise |
◆ golioth_payload_as_float()
| float golioth_payload_as_float |
Convert raw byte payload into a float
- Parameters
- Returns
- float value returned from strtof(payload, NULL)
◆ golioth_payload_as_int()
| int32_t golioth_payload_as_int |
Convert raw byte payload into an int32_t
- Parameters
- Returns
- int32_t value returned from strtol(payload, NULL, 10)
◆ golioth_payload_is_null()
| bool golioth_payload_is_null |
Returns true if payload has no contents
- Parameters
- Return values
| true | payload is NULL, payload_size is 0 or payload is exactly the string "null" |
| false | otherwise |
