All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Macros Modules Pages
golioth_status.h File Reference
Macros
#define FOREACH_GOLIOTH_STATUS(STATUS)
 Status code enum used throughout Golioth SDK.
#define GENERATE_GOLIOTH_STATUS_ENUM(code)   code,
#define GOLIOTH_STATUS_RETURN_IF_ERROR(expr)
Enumerations
enum  golioth_status { FOREACH_GOLIOTH_STATUS =(GENERATE_GOLIOTH_STATUS_ENUM) NUM_GOLIOTH_STATUS_CODES }
Functions
const char * golioth_status_to_str (enum golioth_status status)
Macro Definition Documentation
◆ FOREACH_GOLIOTH_STATUS
#define FOREACH_GOLIOTH_STATUS ( STATUS)
Value:
STATUS(GOLIOTH_OK) /* 0 */ \
STATUS(GOLIOTH_ERR_FAIL) \
STATUS(GOLIOTH_ERR_DNS_LOOKUP) \
STATUS(GOLIOTH_ERR_NOT_IMPLEMENTED) \
STATUS(GOLIOTH_ERR_MEM_ALLOC) \
STATUS(GOLIOTH_ERR_NULL) /* 5 */ \
STATUS(GOLIOTH_ERR_INVALID_FORMAT) \
STATUS(GOLIOTH_ERR_SERIALIZE) \
STATUS(GOLIOTH_ERR_IO) \
STATUS(GOLIOTH_ERR_TIMEOUT) \
STATUS(GOLIOTH_ERR_QUEUE_FULL) /* 10 */ \
STATUS(GOLIOTH_ERR_NOT_ALLOWED) \
STATUS(GOLIOTH_ERR_INVALID_STATE) \
STATUS(GOLIOTH_ERR_NO_MORE_DATA) \
STATUS(GOLIOTH_ERR_NACK) \
STATUS(GOLIOTH_ERR_BAD_REQUEST) /* 15 */ \
STATUS(GOLIOTH_ERR_INVALID_BLOCK_SIZE) \
STATUS(GOLIOTH_ERR_COAP_RESPONSE)
Definition at line 15 of file golioth_status.h.
◆ GENERATE_GOLIOTH_STATUS_ENUM
#define GENERATE_GOLIOTH_STATUS_ENUM ( code)    code,
Definition at line 35 of file golioth_status.h.
◆ GOLIOTH_STATUS_RETURN_IF_ERROR
#define GOLIOTH_STATUS_RETURN_IF_ERROR ( expr)
Value:
do \
enum golioth_status status = (expr); \
if (status != GOLIOTH_OK) \
return status; \
} while (0)
golioth_status
Helper macro, for functions that return type enum golioth_status, if they want to return early when an expression returns something other than GOLIOTH_OK.
Definition at line 51 of file golioth_status.h.
Enumeration Type Documentation
◆ golioth_status
Enumerator
Definition at line 36 of file golioth_status.h.
Function Documentation
◆ golioth_status_to_str()
const char * golioth_status_to_str ( enum golioth_status status)
Convert status code to human-readable string
Parameters
statusstatus code to convert to string
Returns
static string representation of status code
