#include <stdint.h>
#include <inttypes.h>
#include <stdbool.h>
#include <stdlib.h>
#include <golioth/config.h>
◆ GLTH_LOG_BUFFER_HEXDUMP
| #define GLTH_LOG_BUFFER_HEXDUMP |
| TAG, |
◆ GLTH_LOGD
| #define GLTH_LOGD |
| TAG, |
◆ GLTH_LOGE
| #define GLTH_LOGE |
| TAG, |
◆ GLTH_LOGI
| #define GLTH_LOGI |
| TAG, |
◆ GLTH_LOGV
| #define GLTH_LOGV |
| TAG, |
◆ GLTH_LOGW
| #define GLTH_LOGW |
| TAG, |
◆ golioth_sys_free
| #define golioth_sys_free |
| ptr | ) |
free((ptr)) |
◆ golioth_sys_malloc
| #define golioth_sys_malloc |
| sz | ) |
malloc((sz)) |
◆ golioth_sys_rand
| #define golioth_sys_rand |
rand() |
◆ golioth_sys_srand
| #define golioth_sys_srand |
| seed | ) |
srand((seed)) |
◆ GOLIOTH_SYS_WAIT_FOREVER
| #define GOLIOTH_SYS_WAIT_FOREVER -1 |
◆ golioth_sys_mutex_t
◆ golioth_sys_sem_t
◆ golioth_sys_sha256_t
◆ golioth_sys_thread_fn_t
| typedef void(* golioth_sys_thread_fn_t) (void *user_arg) |
◆ golioth_sys_thread_t
◆ golioth_sys_timer_fn_t
◆ golioth_sys_timer_t
◆ golioth_sys_client_connected()
| void golioth_sys_client_connected |
void * | client | ) |
◆ golioth_sys_client_disconnected()
| void golioth_sys_client_disconnected |
◆ golioth_sys_hex2bin()
| size_t golioth_sys_hex2bin |
const char * | hex, |
size_t | hexlen, |
uint8_t * | buf, |
size_t | buflen ) |
Convert a string of hexadecimal values to an array of bytes
- Parameters
| hex | Pointer at a hexadecimal string. |
| hexlen | Length of the hex string. |
| buf | A buffer where binary values will be written. |
| buflen | Length of the binary buffer. |
- Returns
- GOLIOTH_OK On success
GOLIOTH_ERR_FAIL On failure
◆ golioth_sys_msleep()
| void golioth_sys_msleep |
uint32_t | ms | ) |
◆ golioth_sys_mutex_create()
◆ golioth_sys_mutex_destroy()
◆ golioth_sys_mutex_lock()
◆ golioth_sys_mutex_unlock()
◆ golioth_sys_now_ms()
| uint64_t golioth_sys_now_ms |
void | | ) |
◆ golioth_sys_sem_create()
| golioth_sys_sem_t golioth_sys_sem_create |
uint32_t | sem_max_count, |
uint32_t | sem_initial_count ) |
◆ golioth_sys_sem_destroy()
◆ golioth_sys_sem_get_fd()
◆ golioth_sys_sem_give()
◆ golioth_sys_sem_take()
◆ golioth_sys_sha256_create()
Create a context for generating a sha256 hash.
Dynamically creates and initializes a context, then returns an opaque handle to the context. The handle is a required parameter for all other Golioth sha256 functions.
- Returns
- Non-NULL The sha256 context handle (success)
NULL There was an error creating the context
◆ golioth_sys_sha256_destroy()
Destroys a Golioth sha256 context
Frees memory dynamically allocated for golioth_sys_sha256_t context handle by golioth_sys_sha256_create.
- Parameters
| sha_ctx | A sha256 context handle |
◆ golioth_sys_sha256_finish()
Finalizes a sha256 hash calculation and outputs to a binary buffer.
- Parameters
| sha_ctx | A sha256 context handle. |
| output | A buffer of exactly 32 bytes where the sha256 value is written. |
- Returns
◆ golioth_sys_sha256_update()
Adds an input buffer into a sha256 hash calculation.
Call on an existing context to add data to the sha256 calculation. May be called repeatedly (eg: each block in a block download) or once for a large data set (eg: calculate the hash after writing all bytes to memory).
- Parameters
| input | Input buffer to be added to the sha256 calculation |
| len | Length of the input buffer, in bytes. |
- Returns
◆ golioth_sys_thread_create()
◆ golioth_sys_thread_destroy()
◆ golioth_sys_timer_create()
◆ golioth_sys_timer_destroy()
◆ golioth_sys_timer_reset()
◆ golioth_sys_timer_start()
