| typedef void(* | golioth_client_event_cb_fn) (struct golioth_client *client, enum golioth_client_event event, void *arg) |
| typedef void(* | golioth_get_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, const uint8_t *payload, size_t payload_size, void *arg) |
| typedef void(* | golioth_set_block_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, size_t block_size, void *arg) |
| typedef enum golioth_status(* | golioth_get_block_cb_fn) (struct golioth_client *client, const char *path, uint32_t block_idx, const uint8_t *block_buffer, size_t block_buffer_len, bool is_last, size_t negotiated_block_size, void *arg) |
| typedef void(* | golioth_end_block_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, uint32_t block_idx, void *arg) |
| typedef void(* | golioth_set_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, void *arg) |
| typedef void(* | golioth_post_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, const uint8_t *payload, size_t payload_size, void *arg) |
Functions for creating a Golioth client and managing client lifetime.
Used to connect to Golioth cloud using the CoAP protocol over DTLS.
For authentication, you can use either pre-shared key (PSK) or X.509 certificates (aka Public Key Infrastructure, PKI).
https://docs.golioth.io/reference/device-api
◆ golioth_client_event_cb_fn
| typedef void(* golioth_client_event_cb_fn) (struct golioth_client *client, enum golioth_client_event event, void *arg) |
Callback function type for client events
- Parameters
Definition at line 133 of file client.h.
◆ golioth_end_block_cb_fn
| typedef void(* golioth_end_block_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, uint32_t block_idx, void *arg) |
Callback at the end of blockwise get requests
The end callback will be called exactly one time at the conclusion of a blockwise download. If the block download is unsuccessful, then block_idx will contain the index of the block that failed to download. Callers may attempt to resume the blockwise download by passing that index to a blockwise get function.
The CoAP response code is available by reading code_class (2.xx) and code_detail (x.00) from coap_rsp_code:
- When
status is GOLIOTH_OK, coap_rsp_code->code_class will be a 2.XX success code.
- When
status is GOLIOTH_COAP_RESPONSE_CODE, check coap_rsp_code->code_class for a non-success code (4.XX, etc.)
- All other
status values indicate an error in which a response was not received. The coap_rsp_code is undefined and will be NULL.
- Parameters
| client | The client handle from the original request. |
| status | Golioth status code. |
| coap_rsp_code | CoAP response code received from Golioth. Can be NULL. |
| path | The path from the original request. |
| block_idx | The last block number received (or where to resume if get failed). the block that failed to download. |
| arg | User argument, copied from the original request. Can be NULL. |
Definition at line 227 of file client.h.
◆ golioth_get_block_cb_fn
| typedef enum golioth_status(* golioth_get_block_cb_fn) (struct golioth_client *client, const char *path, uint32_t block_idx, const uint8_t *block_buffer, size_t block_buffer_len, bool is_last, size_t negotiated_block_size, void *arg) |
Callback for blockwise get requests
Will be called repeatedly, once for each block received from the server. The string offset of the block received by this callback may be calculated by multiplying block_idx by negotiated_block_size.
- Parameters
| path | The path from the original request |
| block_idx | The block number in sequence (starting with 0) |
| block_buffer | The component payload in the response packet. |
| block_buffer_len | The length of the component payload, in bytes. |
| is_last | true if this is the final block of the request |
| negotiated_block_size | The maximum block size negotiated with the server, in bytes |
Definition at line 174 of file client.h.
◆ golioth_get_cb_fn
| typedef void(* golioth_get_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, const uint8_t *payload, size_t payload_size, void *arg) |
Callback function type for all asynchronous get and observe requests
Will be called when a response is received, on timeout (i.e. response never received), or when the request is cancelled (e.g. when the Golioth client is stopped). The callback function should check status to determine which case triggered the callback.
- When
- When
- All other
- Parameters
| payload | The application layer payload in the response packet. Can be NULL. |
| payload_size | The size of payload, in bytes |
Definition at line 158 of file client.h.
◆ golioth_post_cb_fn
| typedef void(* golioth_post_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, const uint8_t *payload, size_t payload_size, void *arg) |
Callback function type for all asynchronous post requests
- When
- When
- All other
- Parameters
| coap_rsp_code | CoAP response code received from Golioth |
Definition at line 281 of file client.h.
◆ golioth_set_block_cb_fn
| typedef void(* golioth_set_block_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, size_t block_size, void *arg) |
Callback function type for blockwise uploads that also returns the blocksize in szx format
- Parameters
| block_size | The block size from the server in bytes |
◆ golioth_set_cb_fn
Callback function type for all asynchronous set and delete requests as well as blockwise uploads
- When
- When
- All other
- Parameters
Definition at line 254 of file client.h.
◆ golioth_auth_type
Authentication type.
| Enumerator |
| GOLIOTH_TLS_AUTH_TYPE_PSK | Authenticate with pre-shared key (psk-id and psk)
| GOLIOTH_TLS_AUTH_TYPE_PKI | Authenticate with PKI certificates (CA cert, public client cert, private client key)
| GOLIOTH_TLS_AUTH_TYPE_TAG | Authenticate with TLS credential tag (Zephyr specific)
Definition at line 62 of file client.h.
Golioth client events.
| Enumerator |
| GOLIOTH_CLIENT_EVENT_CONNECTED | Client was previously not connected, and is now connected.
| GOLIOTH_CLIENT_EVENT_DISCONNECTED | Client was previously connected, and is now disconnected.
Definition at line 35 of file client.h.
◆ golioth_content_type
Golioth Content Type.
| Enumerator |
| GOLIOTH_CONTENT_TYPE_JSON | |
| GOLIOTH_CONTENT_TYPE_CBOR | |
| GOLIOTH_CONTENT_TYPE_OCTET_STREAM | |
Definition at line 44 of file client.h.
◆ golioth_client_create()
Create a Golioth client
Dynamically creates a client and returns an opaque handle to the client. The handle is a required parameter for most other Golioth SDK functions.
An RTOS thread and request queue is created and the client is automatically started (no need to call golioth_client_start).
- Parameters
| config | Client configuration |
- Returns
- Non-NULL The client handle (success)
NULL There was an error creating the client
◆ golioth_client_destroy()
| void golioth_client_destroy |
struct golioth_client * | client | ) |
Destroy a Golioth client
Frees dynamically created resources from golioth_client_create.
- Parameters
| client | The handle of the client to destroy |
◆ golioth_client_get_thread()
Return the thread handle of the client thread.
- Parameters
- Returns
- The thread handle of the client thread
◆ golioth_client_is_connected()
| bool golioth_client_is_connected |
Returns whether the client is currently connected to Golioth servers.
If client requests receive responses, this is the indication of being connected. If requests time out (no response from server), then the client is considered disconnected.
- Parameters
- Return values
| true | The client is connected to Golioth |
| false | The client is not connected, or the client handle is not valid |
◆ golioth_client_is_running()
| bool golioth_client_is_running |
Returns whether the client is currently running
- Parameters
- Return values
| true | The client is running |
| false | The client is not running, or the client handle is not valid |
◆ golioth_client_num_items_in_request_queue()
| uint32_t golioth_client_num_items_in_request_queue |
The number of items currently in the client thread request queue.
Will be a number between 0 and GOLIOTH_COAP_REQUEST_QUEUE_MAX_ITEMS.
- Parameters
- Returns
- The number of items currently in the client thread request queue.
◆ golioth_client_register_event_callback()
Register a callback that will be called on client events (e.g. connected, disconnected)
- Parameters
| client | The client handle |
| callback | Callback function to register |
| arg | Optional argument, forwarded directly to the callback when invoked. Can be NULL. |
◆ golioth_client_set_packet_loss_percent()
| void golioth_client_set_packet_loss_percent |
uint8_t | percent | ) |
Simulate packet loss at a particular percentage (0 to 100).
Intended for testing and troubleshooting in packet loss scenarios. Does nothing if percent is outside of the range [0, 100].
- Parameters
| percent | Percent packet loss (0 is no packets lost, 100 is all packets lost) |
◆ golioth_client_start()
| enum golioth_status golioth_client_start |
Start the Golioth client
Does nothing if the client is already started. The client is started after calling golioth_client_create.
- Parameters
- Return values
| GOLIOTH_OK | Client started |
| GOLIOTH_ERR_NULL | Client handle invalid |
◆ golioth_client_stop()
| enum golioth_status golioth_client_stop |
Stop the Golioth client
Client will finish the current request (if there is one), then enter a dormant state where no packets will be sent or received with Golioth, and the client thread will be in a blocked state.
This function will block until the client thread is actually stopped.
Does nothing if the client is already stopped.
- Parameters
- Return values
| GOLIOTH_OK | Client stopped |
◆ golioth_client_wait_for_connect()
| bool golioth_client_wait_for_connect |
struct golioth_client * | client, |
int | timeout_ms ) |
Wait (block) until connected to Golioth, or timeout occurs.
If timeout_ms set to -1, it will wait forever until connected.
- Parameters
| timeout_ms | How long to wait, in milliseconds, or -1 to wait forever |
- Returns
- True, if connected, false otherwise.
