Typedefs | |
| typedef enum golioth_status(* | stream_read_block_cb) (uint32_t block_idx, uint8_t *block_buffer, size_t *block_size, bool *is_last, void *arg) |
Functions | |
| enum golioth_status | golioth_stream_set (struct golioth_client *client, const char *path, enum golioth_content_type content_type, const uint8_t *buf, size_t buf_len, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_stream_set_blockwise_sync (struct golioth_client *client, const char *path, enum golioth_content_type content_type, stream_read_block_cb cb, void *arg) |
| struct blockwise_transfer * | golioth_stream_blockwise_start (struct golioth_client *client, const char *path, enum golioth_content_type content_type) |
| void | golioth_stream_blockwise_finish (struct blockwise_transfer *ctx) |
| enum golioth_status | golioth_stream_blockwise_set_block (struct blockwise_transfer *ctx, uint32_t block_idx, const uint8_t *block_buffer, size_t data_len, bool is_last, golioth_set_block_cb_fn callback, void *callback_arg) |
Functions for interacting with Golioth Stream service.
https://docs.golioth.io/reference/protocols/coap/stream
| typedef enum golioth_status(* stream_read_block_cb) (uint32_t block_idx, uint8_t *block_buffer, size_t *block_size, bool *is_last, void *arg) |
Read block callback
This callback will be called by the Golioth client each time it needs to fill a block.
When the callback runs, the buffer should be filled with block_size number of bytes. When the last block contains fewer bytes, set block_size to the actual number of bytes written. Set is_last to indicate all data has been written to buffer.
| block_idx | The index of the block to fill |
| block_buffer | The buffer that this callback should fill |
| block_size | (in/out) Contains the maximum size of block_buffer, and should be set to the size of data actually placed in block_buffer. Value must be > 0 when this function returns GOLIOTH_OK. |
| is_last | (out) Set this to true if this is the last block to transfer |
| arg | A user provided argument |
| GOLIOTH_OK | Callback ran successfully |
| GOLIOTH_ERR_* | Indicate error type encountered by callback |
| void golioth_stream_blockwise_finish | ( | struct blockwise_transfer * | ctx | ) |
Destroy a multi-block upload context
Free the memory allocated for a given multi-block upload context.
| ctx | Block upload context to be destroyed |
| enum golioth_status golioth_stream_blockwise_set_block | ( | struct blockwise_transfer * | ctx, |
| uint32_t | block_idx, | ||
| const uint8_t * | block_buffer, | ||
| size_t | data_len, | ||
| bool | is_last, | ||
| golioth_set_block_cb_fn | callback, | ||
| void * | callback_arg ) |
Set an object in stream at a particular path by sending each block
Call this function for each block. For each call you must increment the block_idx, adjust the block_buffer pointer and update the data_len. On the final block, set is_last to true. Block size is determined by the value of CONFIG_GOLIOTH_BLOCKWISE_DOWNLOAD_MAX_BLOCK_SIZE.
Create a new ctx by calling golioth_stream_blockwise_start. The same ctx must be used for all blocks in a related upload. Generate a new ctx for each new upload operation. Free the context memory by calling golioth_stream_blockwise_finish.
An optional callback and callback argument may be supplied. The callback will be called after the block is uploaded to provide access to status and CoAP response codes.
| ctx | Block upload context used for all blocks in a related upload operation |
| block_idx | The index of the block being sent |
| block_buffer | The buffer where the data for this block is located |
| data_len | The actual length of data (in bytes) for this block. This should be equal to CONFIG_GOLIOTH_BLOCKWISE_DOWNLOAD_MAX_BLOCK_SIZE for all blocks except for the final block, which may be shorter |
| is_last | Set this to true if this is the last block in the upload |
| callback | A callback that will be called after each block is sent (can be NULL) |
| callback_arg | An optional user provided argument that will be passed to callback (can be NULL) |
| struct blockwise_transfer * golioth_stream_blockwise_start | ( | struct golioth_client * | client, |
| const char * | path, | ||
| enum golioth_content_type | content_type ) |
Create a multipart blockwise upload context
Creates the context and returns a pointer to it. This context is used to associate all blocks of a multipart upload together. A new context is needed at the start of each multipart blockwise upload operation.
| client | The client handle from golioth_client_create |
| path | The path in stream to set (e.g. "my_obj") |
| content_type | The content type of the object (e.g. JSON or CBOR) |
| enum golioth_status golioth_stream_set | ( | struct golioth_client * | client, |
| enum golioth_content_type | content_type, | ||
| const uint8_t * | buf, | ||
| size_t | buf_len, | ||
| golioth_set_cb_fn | callback, | ||
Set an object in stream at a particular path asynchronously
This function will enqueue a request and return immediately without waiting for a response from the server. Optionally, the user may supply a callback that will be called when the response is received (indicating the request was acknowledged by the server) or a timeout occurs (response never received).
| content_type | The serialization format of buf |
| buf | A buffer containing the object to send |
| buf_len | Length of buf |
| callback | Callback to call on response received or timeout. Can be NULL. |
| callback_arg | Callback argument, passed directly when callback invoked. Can be NULL. |
| GOLIOTH_OK | request enqueued |
| GOLIOTH_ERR_NULL | invalid client handle |
| GOLIOTH_ERR_INVALID_STATE | client is not running, currently stopped |
| GOLIOTH_ERR_MEM_ALLOC | memory allocation error |
| GOLIOTH_ERR_QUEUE_FULL | request queue is full, this request is dropped |
| enum golioth_status golioth_stream_set_blockwise_sync | ( | struct golioth_client * | client, |
| stream_read_block_cb | cb, | ||
| void * | arg ) |
Set an object in stream at a particular path synchronously
This function will block until the whole transfer is complete, or errors out.
| cb | A callback that will be used to fill each block in the transfer |
| arg | An optional user provided argument that will be passed to cb |
