#include <golioth/golioth_status.h>#include <golioth/client.h>#include <golioth/config.h>#include <stdint.h>#include <stdbool.h>Go to the source code of this file.
Typedefs | |
| typedef enum golioth_settings_status(* | golioth_int_setting_cb) (int32_t new_value, void *arg) |
| typedef enum golioth_settings_status(* | golioth_bool_setting_cb) (bool new_value, void *arg) |
| typedef enum golioth_settings_status(* | golioth_float_setting_cb) (float new_value, void *arg) |
| typedef enum golioth_settings_status(* | golioth_string_setting_cb) (const char *new_value, size_t new_value_len, void *arg) |
Enumerations | |
| enum | golioth_settings_status { GOLIOTH_SETTINGS_SUCCESS = 0 , GOLIOTH_SETTINGS_KEY_NOT_RECOGNIZED = 1 , GOLIOTH_SETTINGS_KEY_NOT_VALID = 2 , GOLIOTH_SETTINGS_VALUE_FORMAT_NOT_VALID = 3 , GOLIOTH_SETTINGS_VALUE_OUTSIDE_RANGE = 4 , GOLIOTH_SETTINGS_VALUE_STRING_TOO_LONG = 5 , GOLIOTH_SETTINGS_GENERAL_ERROR = 6 } |
| Enumeration of Settings status codes. More... | |
| enum | golioth_settings_value_type { GOLIOTH_SETTINGS_VALUE_TYPE_UNKNOWN , GOLIOTH_SETTINGS_VALUE_TYPE_INT , GOLIOTH_SETTINGS_VALUE_TYPE_BOOL , GOLIOTH_SETTINGS_VALUE_TYPE_FLOAT , GOLIOTH_SETTINGS_VALUE_TYPE_STRING } |
| Different types of setting values. More... | |
Functions | |
| struct golioth_settings * | golioth_settings_init (struct golioth_client *client) |
| enum golioth_status | golioth_settings_deinit (struct golioth_settings *settings) |
| enum golioth_status | golioth_settings_register_int (struct golioth_settings *settings, const char *setting_name, golioth_int_setting_cb callback, void *callback_arg) |
| enum golioth_status | golioth_settings_register_int_with_range (struct golioth_settings *settings, const char *setting_name, int32_t min_val, int32_t max_val, golioth_int_setting_cb callback, void *callback_arg) |
| enum golioth_status | golioth_settings_register_bool (struct golioth_settings *settings, const char *setting_name, golioth_bool_setting_cb callback, void *callback_arg) |
| Same as golioth_settings_register_int, but for type bool. | |
| enum golioth_status | golioth_settings_register_float (struct golioth_settings *settings, const char *setting_name, golioth_float_setting_cb callback, void *callback_arg) |
| Same as golioth_settings_register_int, but for type float. | |
| enum golioth_status | golioth_settings_register_string (struct golioth_settings *settings, const char *setting_name, golioth_string_setting_cb callback, void *callback_arg) |
| Same as golioth_settings_register_int, but for type string. | |
