Loading...
Searching...
No Matches
golioth_ota_manifest Struct Reference
An OTA manifest, composed of multiple components/artifacts. More...
#include <ota.h>
Data Fields
int32_t seqnum
 OTA release sequence number.
struct golioth_ota_component components [CONFIG_GOLIOTH_OTA_MAX_NUM_COMPONENTS]
 An array of artifacts.
size_t num_components
 Number of artifacts.
Detailed Description
Definition at line 91 of file ota.h.
Field Documentation
◆ components
struct golioth_ota_component golioth_ota_manifest::components[CONFIG_GOLIOTH_OTA_MAX_NUM_COMPONENTS]
Definition at line 96 of file ota.h.
◆ num_components
size_t golioth_ota_manifest::num_components
Definition at line 98 of file ota.h.
◆ seqnum
int32_t golioth_ota_manifest::seqnum
Definition at line 94 of file ota.h.
The documentation for this struct was generated from the following file:
