Loading...
Searching...
No Matches
golioth_ota
Data Structures
struct  golioth_ota_component
 A component/artifact within an OTA manifest. More...
struct  golioth_ota_manifest
 An OTA manifest, composed of multiple components/artifacts. More...
Macros
#define GOLIOTH_OTA_COMPONENT_HEX_HASH_LEN   64
 Size of a SHA256 of Artifact hex string in bytes.
#define GOLIOTH_OTA_COMPONENT_BIN_HASH_LEN   32
 Size of a SHA256 of Artifact bin array in bytes.
#define GOLIOTH_OTA_MAX_COMPONENT_URI_LEN    (CONFIG_GOLIOTH_OTA_MAX_PACKAGE_NAME_LEN + CONFIG_GOLIOTH_OTA_MAX_VERSION_LEN + 7)
 Maximum size of Relative URI to download binary (+ 7 bytes for Path)
Typedefs
typedef enum golioth_status(* ota_component_block_write_cb) (const struct golioth_ota_component *component, uint32_t block_idx, const uint8_t *block_buffer, size_t block_buffer_len, bool is_last, size_t negotiated_block_size, void *arg)
typedef void(* ota_component_download_end_cb) (enum golioth_status status, const struct golioth_coap_rsp_code *rsp_code, const struct golioth_ota_component *component, uint32_t block_idx, void *arg)
Enumerations
enum  golioth_ota_state { GOLIOTH_OTA_STATE_IDLE , GOLIOTH_OTA_STATE_DOWNLOADING , GOLIOTH_OTA_STATE_DOWNLOADED , GOLIOTH_OTA_STATE_UPDATING }
 State of OTA update, reported to Golioth server. More...
enum  golioth_ota_reason {
  GOLIOTH_OTA_REASON_READY , GOLIOTH_OTA_REASON_FIRMWARE_UPDATED_SUCCESSFULLY , GOLIOTH_OTA_REASON_NOT_ENOUGH_FLASH_MEMORY , GOLIOTH_OTA_REASON_OUT_OF_RAM ,
  GOLIOTH_OTA_REASON_CONNECTION_LOST , GOLIOTH_OTA_REASON_INTEGRITY_CHECK_FAILURE , GOLIOTH_OTA_REASON_UNSUPPORTED_PACKAGE_TYPE , GOLIOTH_OTA_REASON_INVALID_URI ,
  GOLIOTH_OTA_REASON_FIRMWARE_UPDATE_FAILED , GOLIOTH_OTA_REASON_UNSUPPORTED_PROTOCOL , GOLIOTH_OTA_REASON_IO , GOLIOTH_OTA_REASON_AWAIT_RETRY
 A reason associated with state changes. More...
Functions
enum golioth_status golioth_ota_payload_as_manifest (const uint8_t *payload, size_t payload_size, struct golioth_ota_manifest *manifest)
size_t golioth_ota_size_to_nblocks (size_t component_size)
const struct golioth_ota_component * golioth_ota_find_component (const struct golioth_ota_manifest *manifest, const char *package)
enum golioth_status golioth_ota_manifest_subscribe (struct golioth_client *client, golioth_get_cb_fn callback, void *arg)
enum golioth_status golioth_ota_get_manifest (struct golioth_client *client, golioth_get_cb_fn callback, void *arg)
enum golioth_status golioth_ota_blockwise_manifest (struct golioth_client *client, size_t block_idx, golioth_get_block_cb_fn block_cb, golioth_end_block_cb_fn end_cb, void *arg)
enum golioth_status golioth_ota_download_component (struct golioth_client *client, const struct golioth_ota_component *component, uint32_t block_idx, ota_component_block_write_cb block_cb, ota_component_download_end_cb end_cb, void *arg)
enum golioth_status golioth_ota_report_state (struct golioth_client *client, enum golioth_ota_state state, enum golioth_ota_reason reason, const char *package, const char *current_version, const char *target_version, golioth_set_cb_fn callback, void *callback_arg)
enum golioth_ota_state golioth_ota_get_state (void)
Detailed Description
Functions for interacting with Golioth OTA services
https://docs.golioth.io/reference/device-api/api-docs/ota
Macro Definition Documentation
◆ GOLIOTH_OTA_COMPONENT_BIN_HASH_LEN
Definition at line 28 of file ota.h.
◆ GOLIOTH_OTA_COMPONENT_HEX_HASH_LEN
Definition at line 26 of file ota.h.
◆ GOLIOTH_OTA_MAX_COMPONENT_URI_LEN
Definition at line 30 of file ota.h.
Typedef Documentation
◆ ota_component_block_write_cb
Callback for OTA download component request
Will be called 0 or more times, once for each block received from the server.
Parameters
componentThe golioth_ota_component pointer from the original request
block_idxThe block number in sequence (starting with 0)
block_bufferThe component payload in the response packet.
block_buffer_lenThe length of the component payload, in bytes.
is_lasttrue if this is the final block of the request
negotiated_block_sizeThe maximum block size negotated with the server, in bytes
argUser argument, copied from the original request. Can be NULL.
Definition at line 171 of file ota.h.
◆ ota_component_download_end_cb
Callback for the end of an OTA download
Will be called exactly one time for each successful call to golioth_ota_download_component
Parameters
statusThe result of the blockwise download
rsp_codeIf status is GOLIOTH_ERR_COAP_RESPONSE then this pointer contains the CoAP response code
block_idxThe Users can resume an OTA download by passing this value to the block_idx argument of golioth_ota_download_component
argUser supplied argument. Can be NULL.
Definition at line 208 of file ota.h.
Enumeration Type Documentation
◆ golioth_ota_reason
Enumerator
OTA update is ready to go. Also used for "no reason".
Firmware update was successful.
Insufficient flash memory on device.
Insufficient RAM on device.
Lost connection to server during OTA update.
Data integrity check of downloaded artifact failed.
Package type not supported.
URI not valid.
Firmware update was not successful.
Protocol not supported.
IO error while trying to store component.
Awaiting retry.
Definition at line 47 of file ota.h.
◆ golioth_ota_state
Enumerator
No OTA update in progress.
OTA is being downloaded and written to flash.
OTA has been downloaded and written to flash.
OTA is being applied to the system, but is not yet complete.
Definition at line 34 of file ota.h.
Function Documentation
◆ golioth_ota_blockwise_manifest()
enum golioth_status golioth_ota_blockwise_manifest ( struct golioth_client * client,
size_t block_idx,
void * arg )
Get the OTA manifest using blockwise download
Use this function to perform a blockwise get of the OTA manifest in CBOR format. This may be used to retrieve manifests of any size, but is required to get a manifest that is larger than CONFIG_GOLIOTH_BLOCKWISE_DOWNLOAD_MAX_BLOCK_SIZE (1024 bytes or smaller).
This function will enqueue a request and return immediately without waiting for a response from the server. The block_cb will be called once for each block received from the server. The end_cb will be called exactly one time at the conclusion (successful or otherwise) of the manifest download.
Parameters
clientThe client handle from golioth_client_create
block_idxThe index of the first block to download. Callers can resume a blockwise download by passing in a non-zero block_idx.
block_cbCallback for receiving a block of data. See golioth_get_block_cb_fn
end_cbCallabck for the end of a download. See golioth_end_block_cb_fn
argOptional argument, forwarded directly to the callback when invoked. Can be NULL.
◆ golioth_ota_download_component()
enum golioth_status golioth_ota_download_component ( struct golioth_client * client,
const struct golioth_ota_component * component,
uint32_t block_idx,
void * arg )
Begin or resume downloading an OTA component synchronously.
This function will block until the final block of the component download is received from the server or an error is received on any block. The next_block_idx is used to pass in the first block index to be downloaded (components begin with the 0th index). After returning, the same parameter has been updated to indicate the next expected block in the download process.
Use this function to resume OTA component downloads. Pass the next_block_idx from a failed run to resume the download. The ota_component_block_write_cb function must be designed to handle storage when resuming a download. Upon successful completion, it is up to the application to verify the integrity of the component (eg: compare to the SHA256 in struct golioth_ota_component).
Parameters
componentOne golioth_ota_component instance present in the golioth_ota_manifest
block_cbCallback for receiving a block of data. See ota_component_block_write_cb
end_cbCallabck for the end of a download. See ota_component_download_end_cb
Return values
GOLIOTH_OKthe final block of package was received
GOLIOTH_ERR_FAILinvalid client handle, path, or callback
GOLIOTH_ERR_MEM_ALLOCunable to allocate necessary memory
◆ golioth_ota_find_component()
const struct golioth_ota_component * golioth_ota_find_component ( const struct golioth_ota_manifest * manifest,
const char * package )
Find a component by package name in a manifest, or NULL if not found.
Parameters
manifestmanifest to find component in
packagepackage name to find in manifest
Returns
if found - pointer to component
if not found - NULL
◆ golioth_ota_get_manifest()
enum golioth_status golioth_ota_get_manifest ( struct golioth_client * client,
void * arg )
This function will enqueue a request and return immediately without waiting for a response from the server. The callback will be invoked when the manifest is received from the Golioth server.
Parameters
callbackCallback function to register
◆ golioth_ota_get_state()
enum golioth_ota_state golioth_ota_get_state ( void )
Get the current state of OTA update
Returns
The current OTA update state
◆ golioth_ota_manifest_subscribe()
enum golioth_status golioth_ota_manifest_subscribe ( struct golioth_client * client,
void * arg )
Subscribe for updates to the OTA manifest
This function subscribes to updates to the Golioth OTA manifest. Updates will be fetched every CONFIG_GOLIOTH_OTA_MANIFEST_SUBSCRIPTION_POLL_INTERVAL_S seconds. Updates will also be pushed directly to the device if a manifest changes while the device is connected.
Parameters
◆ golioth_ota_payload_as_manifest()
enum golioth_status golioth_ota_payload_as_manifest ( const uint8_t * payload,
struct golioth_ota_manifest * manifest )
Convert raw byte payload into a golioth_ota_manifest
Parameters
payloadPointer to payload data
payload_sizeSize of payload, in bytes
manifestOutput param, memory allocated by caller, populated with manifest
Return values
GOLIOTH_OKpayload converted to struct golioth_ota_manifest
GOLIOTH_ERR_INVALID_FORMATfailed to parse manifest
◆ golioth_ota_report_state()
enum golioth_status golioth_ota_report_state ( struct golioth_client * client,
const char * package,
const char * current_version,
const char * target_version,
void * callback_arg )
Report the state of OTA update to Golioth server
This function will enqueue a request and return immediately without waiting for a response from the server. Optionally, the user may supply a callback that will be called when the response is received (indicating the request was acknowledged by the server) or a timeout occurs (response never received).
Parameters
stateThe OTA update state
reasonThe reason for this state change
packageThe artifact package name
current_versionThe artifact current_version. Can be NULL.
target_versionThe artifact new/target version from manifest. Can be NULL.
callbackCallback to call on response received or timeout. Can be NULL.
callback_argCallback argument, passed directly when callback invoked. Can be NULL.
Return values
GOLIOTH_OKrequest enqueued
GOLIOTH_ERR_NULLinvalid client handle
GOLIOTH_ERR_INVALID_STATEclient is not running, currently stopped
GOLIOTH_ERR_QUEUE_FULLrequest queue is full, this request is dropped
◆ golioth_ota_size_to_nblocks()
size_t golioth_ota_size_to_nblocks ( size_t component_size)
Convert a size in bytes to the number of blocks required (of size up to GOLIOTH_BLOCKWISE_DOWNLOAD_MAX_BLOCK_SIZE)
