#include <golioth/golioth_status.h>
#include <golioth/client.h>
#include <stdlib.h>
| struct gateway_uplink * | golioth_gateway_uplink_start (struct golioth_client *client, gateway_downlink_block_cb dnlk_block_cb, gateway_downlink_end_cb dnlk_end_cb, void *downlink_arg) |
| enum golioth_status | golioth_gateway_uplink_block (struct gateway_uplink *uplink, uint32_t block_idx, const uint8_t *buf, size_t buf_len, bool is_last, golioth_set_block_cb_fn set_cb, void *callback_arg) |
| void | golioth_gateway_uplink_finish (struct gateway_uplink *uplink) |
| enum golioth_status | golioth_gateway_server_cert_get (struct golioth_client *client, void *buf, size_t *len) |
| enum golioth_status | golioth_gateway_device_cert_set (struct golioth_client *client, const void *buf, size_t len, golioth_set_cb_fn set_cb, void *callback_arg, int32_t timeout_s) |
◆ gateway_downlink_block_cb
| typedef enum golioth_status(* gateway_downlink_block_cb) (const uint8_t *data, size_t len, bool is_last, void *arg) |
◆ gateway_downlink_end_cb
◆ golioth_gateway_device_cert_set()
| enum golioth_status golioth_gateway_device_cert_set |
struct golioth_client * | client, |
const void * | buf, |
size_t | len, |
golioth_set_cb_fn | set_cb, |
void * | callback_arg, |
int32_t | timeout_s ) |
Set device certificate.
- Parameters
| client | The client handle from golioth_client_create |
| buf | Pointer to buffer where certificate is stored |
| len | Certificate length |
| set_cb | A callback that will be called after certificate is set (can be NULL) |
| callback_arg | An optional user provided argument that will be passed to set_cb (can be NULL) |
| timeout_s | Timeout in seconds for API call |
◆ golioth_gateway_server_cert_get()
| enum golioth_status golioth_gateway_server_cert_get |
void * | buf, |
size_t * | len ) |
Get server certificate.
- Parameters
| buf | Pointer to buffer where certificate will be written |
| len | Pointer to length. On input it is buffer length. On output it is certificate length. |
◆ golioth_gateway_uplink_block()
| enum golioth_status golioth_gateway_uplink_block |
struct gateway_uplink * | uplink, |
uint32_t | block_idx, |
const uint8_t * | buf, |
size_t | buf_len, |
bool | is_last, |
golioth_set_block_cb_fn | set_cb, |
void * | callback_arg ) |
Send a single uplink block
Call this function for each block. For each call you must increment the block_idx, On the final block, set is_last to true. Block size is determined by the value of CONFIG_GOLIOTH_BLOCKWISE_DOWNLOAD_MAX_BLOCK_SIZE.
An optional callback and callback argument may be supplied. The callback will be called after the block is uploaded to provide access to status and CoAP response codes.
- Parameters
| uplink | The context used for all blocks in an uplink / downlink operation, returned from golioth_gateway_uplink_start |
| block_idx | The index of the block being sent |
| buf | The buffer where the data for this block is located |
| buf_len | The actual length of data (in bytes) for this block. This should be equal to CONFIG_GOLIOTH_BLOCKWISE_DOWNLOAD_MAX_BLOCK_SIZE for all blocks except for the final block, which may be shorter |
| is_last | Set this to true if this is the last block in the upload |
| set_cb | A callback that will be called after each block is sent (can be NULL) |
◆ golioth_gateway_uplink_finish()
| void golioth_gateway_uplink_finish |
struct gateway_uplink * | uplink | ) |
Finish a gateway uplink.
- Parameters
◆ golioth_gateway_uplink_start()
Start a gateway uplink. The pointer returned from this function can be used with golioth_gateway_uplink_block and golioth_gateway_uplink_finish
- Parameters
| dnlk_block_cb | A callback that will be called after each block in downlink is received |
| dnlk_end_cb | A callback that will be called after downlink completes |
| downlink_arg | An optional user provided argument that will be passed to callbacks (can be NULL) |
