Functions | |
| enum golioth_status | golioth_lightdb_set_int (struct golioth_client *client, const char *path, int32_t value, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_set_bool (struct golioth_client *client, const char *path, bool value, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_set_float (struct golioth_client *client, const char *path, float value, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_set_string (struct golioth_client *client, const char *path, const char *str, size_t str_len, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_set (struct golioth_client *client, const char *path, enum golioth_content_type content_type, const uint8_t *buf, size_t buf_len, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_get (struct golioth_client *client, const char *path, enum golioth_content_type content_type, golioth_get_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_delete (struct golioth_client *client, const char *path, golioth_set_cb_fn callback, void *callback_arg) |
| enum golioth_status | golioth_lightdb_observe (struct golioth_client *client, const char *path, enum golioth_content_type content_type, golioth_get_cb_fn callback, void *callback_arg) |
Functions for interacting with Golioth LightDB State service.
https://docs.golioth.io/reference/device-api/api-docs/lightdb
| enum golioth_status golioth_lightdb_delete | ( | struct golioth_client * | client, |
| const char * | path, | ||
| golioth_set_cb_fn | callback, | ||
| void * | callback_arg ) |
Delete a path in LightDB state
This function will enqueue a request and return immediately without waiting for a response from the server. The callback will be invoked when a response is received or a timeout occurs.
Note: the server responds with success even if the path does not exist in LightDB state.
| client | The client handle from golioth_client_create |
| path | The path in LightDB state to delete (e.g. "my_integer") |
| callback | Callback to call on response received or timeout. Can be NULL. |
| callback_arg | Callback argument, passed directly when callback invoked. Can be NULL. |
| GOLIOTH_OK | request enqueued |
| GOLIOTH_ERR_NULL | invalid client handle |
| GOLIOTH_ERR_INVALID_STATE | client is not running, currently stopped |
| GOLIOTH_ERR_MEM_ALLOC | memory allocation error |
| GOLIOTH_ERR_QUEUE_FULL | request queue is full, this request is dropped |
| enum golioth_status golioth_lightdb_get | ( | struct golioth_client * | client, |
| enum golioth_content_type | content_type, | ||
| golioth_get_cb_fn | callback, | ||
Get data in LightDB state at a particular path
The data passed into the callback function will be the raw payload bytes from the server response. The callback function can convert the payload to the appropriate type using, e.g. golioth_payload_as_int, or using a parsing library (like cJSON or zCBOR) in the case of a serialized object payload
| path | The path in LightDB state to get (e.g. "my_integer") |
| content_type | The serialization format to request for the path |
| enum golioth_status golioth_lightdb_observe | ( | struct golioth_client * | client, |
Observe a path in LightDB state
Observations allow the Golioth server to notify clients of a change in data at a particular path, without the client having to poll for changes.
This function will enqueue a request and return immediately without waiting for a response from the server. The callback will be invoked whenever the data at path changes.
The data passed into the callback function will be the raw payload bytes from the server. The callback function can convert the payload to the appropriate type using, e.g. golioth_payload_as_int, or using a JSON parsing library (like cJSON) in the case of JSON payload.
| path | The path in LightDB state to observe (e.g. "my_integer") |
| enum golioth_status golioth_lightdb_set | ( | struct golioth_client * | client, |
| const uint8_t * | buf, | ||
| size_t | buf_len, | ||
Set an object in LightDB state at a particular path
The serialization format of the object is specified by the content_type argument. Currently this is either JSON or CBOR.
Similar to golioth_lightdb_set_int.
| path | The path in LightDB state to set (e.g. "my_integer") |
| content_type | The serialization format of buf |
| buf | A buffer containing the object to send |
| buf_len | Length of buf |
| enum golioth_status golioth_lightdb_set_bool | ( | struct golioth_client * | client, |
| bool | value, | ||
Set a bool in LightDB state at a particular path
Same as golioth_lightdb_set_int, but for type bool
| enum golioth_status golioth_lightdb_set_float | ( | struct golioth_client * | client, |
| float | value, | ||
Set a float in LightDB state at a particular path
Same as golioth_lightdb_set_int, but for type float
| enum golioth_status golioth_lightdb_set_int | ( | struct golioth_client * | client, |
| int32_t | value, | ||
Set an integer in LightDB state at a particular path
This function will enqueue a request and return immediately without waiting for a response from the server. Optionally, the user may supply a callback that will be called when the response is received (indicating the request was acknowledged by the server) or a timeout occurs (response never received).
| value | The value to set at path |
| enum golioth_status golioth_lightdb_set_string | ( | struct golioth_client * | client, |
| const char * | str, | ||
| size_t | str_len, | ||
Set a string in LightDB state at a particular path
Same as golioth_lightdb_set_int, but for type string
