#include <stdbool.h>#include <stdint.h>#include <stdlib.h>#include <golioth/golioth_status.h>#include "golioth_sys.h"Go to the source code of this file.
Data Structures | |
| struct | golioth_coap_rsp_code |
| CoAP response code returned by server. More... | |
| struct | golioth_psk_credential |
| struct | golioth_pki_credential |
| struct | golioth_credential |
| TLS Authentication Credential. More... | |
| struct | golioth_client_config |
| Golioth client configuration, passed into golioth_client_create. More... | |
Typedefs | |
| typedef void(* | golioth_client_event_cb_fn) (struct golioth_client *client, enum golioth_client_event event, void *arg) |
| typedef void(* | golioth_get_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, const uint8_t *payload, size_t payload_size, void *arg) |
| typedef void(* | golioth_set_block_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, size_t block_size, void *arg) |
| typedef enum golioth_status(* | golioth_get_block_cb_fn) (struct golioth_client *client, const char *path, uint32_t block_idx, const uint8_t *block_buffer, size_t block_buffer_len, bool is_last, size_t negotiated_block_size, void *arg) |
| typedef void(* | golioth_end_block_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, uint32_t block_idx, void *arg) |
| typedef void(* | golioth_set_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, void *arg) |
| typedef void(* | golioth_post_cb_fn) (struct golioth_client *client, enum golioth_status status, const struct golioth_coap_rsp_code *coap_rsp_code, const char *path, const uint8_t *payload, size_t payload_size, void *arg) |
Enumerations | |
| enum | golioth_client_event { GOLIOTH_CLIENT_EVENT_CONNECTED , GOLIOTH_CLIENT_EVENT_DISCONNECTED } |
| Golioth client events. More... | |
| enum | golioth_content_type { GOLIOTH_CONTENT_TYPE_JSON , GOLIOTH_CONTENT_TYPE_CBOR , GOLIOTH_CONTENT_TYPE_OCTET_STREAM } |
| Golioth Content Type. More... | |
| enum | golioth_auth_type { GOLIOTH_TLS_AUTH_TYPE_PSK , GOLIOTH_TLS_AUTH_TYPE_PKI , GOLIOTH_TLS_AUTH_TYPE_TAG } |
| Authentication type. More... | |
Functions | |
| struct golioth_client * | golioth_client_create (const struct golioth_client_config *config) |
| bool | golioth_client_wait_for_connect (struct golioth_client *client, int timeout_ms) |
| enum golioth_status | golioth_client_start (struct golioth_client *client) |
| enum golioth_status | golioth_client_stop (struct golioth_client *client) |
| void | golioth_client_destroy (struct golioth_client *client) |
| bool | golioth_client_is_running (struct golioth_client *client) |
| bool | golioth_client_is_connected (struct golioth_client *client) |
| void | golioth_client_register_event_callback (struct golioth_client *client, golioth_client_event_cb_fn callback, void *arg) |
| uint32_t | golioth_client_num_items_in_request_queue (struct golioth_client *client) |
| void | golioth_client_set_packet_loss_percent (uint8_t percent) |
| golioth_sys_thread_t | golioth_client_get_thread (struct golioth_client *client) |
