Loading...
Searching...
No Matches
fw_update.h
Go to the documentation of this file.
1/*
2 * Copyright (c) 2022 Golioth, Inc.
3 *
4 * SPDX-License-Identifier: Apache-2.0
5 */
6
7#ifdef __cplusplus
8extern "C"
9{
10#endif
11
12#pragma once
13
14#include <golioth/client.h>
15#include <golioth/ota.h>
16#include <stdbool.h>
17
19{
21 const char *current_version;
24 const char *fw_package_name;
25};
26
32
49void golioth_fw_update_init(struct golioth_client *client, const char *current_version);
50
55void golioth_fw_update_init_with_config(struct golioth_client *client,
56 const struct golioth_fw_update_config *config);
57
64 enum golioth_ota_reason reason,
65 void *user_arg);
66
76 void *user_arg);
77
78//---------------------------------------------------------------------------
79// Backend API for firmware updates. Required to be implemented by port.
80// Not intended to be called by user code.
81//---------------------------------------------------------------------------
82
86
89
95
100
113enum golioth_status fw_update_handle_block(const uint8_t *block,
114 size_t block_size,
115 size_t offset,
116 size_t total_size);
117
123
134enum golioth_status fw_update_check_candidate(const uint8_t *hash, size_t img_size);
135
142
147void fw_update_end(void);
148//---------------------------------------------------------------------------
149
151
152#ifdef __cplusplus
153}
154#endif
golioth_status
enum golioth_status fw_update_post_download(void)
void fw_update_rollback(void)
Initiate a firmware rollback.
void golioth_fw_update_init_with_config(struct golioth_client *client, const struct golioth_fw_update_config *config)
void(* golioth_fw_update_state_change_callback)(enum golioth_ota_state state, enum golioth_ota_reason reason, void *user_arg)
Definition fw_update.h:63
void golioth_fw_update_register_state_change_callback(golioth_fw_update_state_change_callback callback, void *user_arg)
enum golioth_status fw_update_handle_block(const uint8_t *block, size_t block_size, size_t offset, size_t total_size)
void fw_update_cancel_rollback(void)
bool fw_update_is_pending_verify(void)
void fw_update_reboot(void)
enum golioth_status fw_update_change_boot_image(void)
golioth_ota_state
State of OTA update, reported to Golioth server.
Definition ota.h:35
golioth_ota_reason
A reason associated with state changes.
Definition ota.h:48
const char * fw_package_name
Definition fw_update.h:24
const char * current_version
The current firmware version, NULL-terminated, shallow-copied from user. (e.g. "1....
Definition fw_update.h:21
