Loading...
Searching...
No Matches
ota.h File Reference
#include <stdint.h>
#include <golioth/golioth_status.h>
#include <golioth/client.h>
#include <golioth/config.h>
Data Structures
struct  golioth_ota_component
 A component/artifact within an OTA manifest. More...
struct  golioth_ota_manifest
 An OTA manifest, composed of multiple components/artifacts. More...
Macros
#define GOLIOTH_OTA_COMPONENT_HEX_HASH_LEN   64
 Size of a SHA256 of Artifact hex string in bytes.
#define GOLIOTH_OTA_COMPONENT_BIN_HASH_LEN   32
 Size of a SHA256 of Artifact bin array in bytes.
#define GOLIOTH_OTA_MAX_COMPONENT_URI_LEN    (CONFIG_GOLIOTH_OTA_MAX_PACKAGE_NAME_LEN + CONFIG_GOLIOTH_OTA_MAX_VERSION_LEN + 7)
 Maximum size of Relative URI to download binary (+ 7 bytes for Path)
Typedefs
typedef enum golioth_status(* ota_component_block_write_cb) (const struct golioth_ota_component *component, uint32_t block_idx, const uint8_t *block_buffer, size_t block_buffer_len, bool is_last, size_t negotiated_block_size, void *arg)
typedef void(* ota_component_download_end_cb) (enum golioth_status status, const struct golioth_coap_rsp_code *rsp_code, const struct golioth_ota_component *component, uint32_t block_idx, void *arg)
Enumerations
enum  golioth_ota_state { GOLIOTH_OTA_STATE_IDLE , GOLIOTH_OTA_STATE_DOWNLOADING , GOLIOTH_OTA_STATE_DOWNLOADED , GOLIOTH_OTA_STATE_UPDATING }
 State of OTA update, reported to Golioth server. More...
enum  golioth_ota_reason {
  GOLIOTH_OTA_REASON_READY , GOLIOTH_OTA_REASON_FIRMWARE_UPDATED_SUCCESSFULLY , GOLIOTH_OTA_REASON_NOT_ENOUGH_FLASH_MEMORY , GOLIOTH_OTA_REASON_OUT_OF_RAM ,
  GOLIOTH_OTA_REASON_CONNECTION_LOST , GOLIOTH_OTA_REASON_INTEGRITY_CHECK_FAILURE , GOLIOTH_OTA_REASON_UNSUPPORTED_PACKAGE_TYPE , GOLIOTH_OTA_REASON_INVALID_URI ,
  GOLIOTH_OTA_REASON_FIRMWARE_UPDATE_FAILED , GOLIOTH_OTA_REASON_UNSUPPORTED_PROTOCOL , GOLIOTH_OTA_REASON_IO , GOLIOTH_OTA_REASON_AWAIT_RETRY
 A reason associated with state changes. More...
Functions
enum golioth_status golioth_ota_payload_as_manifest (const uint8_t *payload, size_t payload_size, struct golioth_ota_manifest *manifest)
size_t golioth_ota_size_to_nblocks (size_t component_size)
const struct golioth_ota_component * golioth_ota_find_component (const struct golioth_ota_manifest *manifest, const char *package)
enum golioth_status golioth_ota_manifest_subscribe (struct golioth_client *client, golioth_get_cb_fn callback, void *arg)
enum golioth_status golioth_ota_get_manifest (struct golioth_client *client, golioth_get_cb_fn callback, void *arg)
enum golioth_status golioth_ota_blockwise_manifest (struct golioth_client *client, size_t block_idx, golioth_get_block_cb_fn block_cb, golioth_end_block_cb_fn end_cb, void *arg)
enum golioth_status golioth_ota_download_component (struct golioth_client *client, const struct golioth_ota_component *component, uint32_t block_idx, ota_component_block_write_cb block_cb, ota_component_download_end_cb end_cb, void *arg)
enum golioth_status golioth_ota_report_state (struct golioth_client *client, enum golioth_ota_state state, enum golioth_ota_reason reason, const char *package, const char *current_version, const char *target_version, golioth_set_cb_fn callback, void *callback_arg)
enum golioth_ota_state golioth_ota_get_state (void)
