Loading...
Searching...
No Matches
Here is a list of all functions, variables, defines, enums, and typedefs with links to the files they belong to:
- g -
gateway_downlink_block_cb :
gateway.h
gateway_downlink_end_cb :
gateway.h
GENERATE_GOLIOTH_STATUS_ENUM :
golioth_status.h
GLTH_LOG_BUFFER_HEXDUMP :
golioth_sys.h
GLTH_LOGD :
golioth_sys.h
GLTH_LOGE :
golioth_sys.h
GLTH_LOGI :
golioth_sys.h
GLTH_LOGV :
golioth_sys.h
GLTH_LOGW :
golioth_sys.h
golioth_auth_type :
client.h
golioth_bool_setting_cb :
settings.h
golioth_cellular_type :
cellular.h
GOLIOTH_CELLULAR_TYPE_LTECATM :
cellular.h
GOLIOTH_CELLULAR_TYPE_NBIOT :
cellular.h
golioth_client_create() :
client.h
golioth_client_destroy() :
client.h
golioth_client_event :
client.h
golioth_client_event_cb_fn :
client.h
GOLIOTH_CLIENT_EVENT_CONNECTED :
client.h
GOLIOTH_CLIENT_EVENT_DISCONNECTED :
client.h
golioth_client_get_thread() :
client.h
golioth_client_is_connected() :
client.h
golioth_client_is_running() :
client.h
golioth_client_num_items_in_request_queue() :
client.h
golioth_client_register_event_callback() :
client.h
golioth_client_set_packet_loss_percent() :
client.h
golioth_client_start() :
client.h
golioth_client_stop() :
client.h
golioth_client_wait_for_connect() :
client.h
golioth_content_type :
client.h
GOLIOTH_CONTENT_TYPE_CBOR :
client.h
GOLIOTH_CONTENT_TYPE_JSON :
client.h
GOLIOTH_CONTENT_TYPE_OCTET_STREAM :
client.h
golioth_debug_get_log_level() :
golioth_debug.h
golioth_debug_hexdump() :
golioth_debug.h
golioth_debug_log_level :
golioth_debug.h
GOLIOTH_DEBUG_LOG_LEVEL_DEBUG :
golioth_debug.h
GOLIOTH_DEBUG_LOG_LEVEL_ERROR :
golioth_debug.h
GOLIOTH_DEBUG_LOG_LEVEL_INFO :
golioth_debug.h
GOLIOTH_DEBUG_LOG_LEVEL_NONE :
golioth_debug.h
GOLIOTH_DEBUG_LOG_LEVEL_VERBOSE :
golioth_debug.h
GOLIOTH_DEBUG_LOG_LEVEL_WARN :
golioth_debug.h
golioth_debug_printf() :
golioth_debug.h
golioth_debug_set_client() :
golioth_debug.h
golioth_debug_set_cloud_log_enabled() :
golioth_debug.h
golioth_debug_set_log_level() :
golioth_debug.h
golioth_end_block_cb_fn :
client.h
golioth_float_setting_cb :
settings.h
golioth_gateway_device_cert_set() :
gateway.h
golioth_gateway_server_cert_get() :
gateway.h
golioth_gateway_uplink_block() :
gateway.h
golioth_gateway_uplink_finish() :
gateway.h
golioth_gateway_uplink_start() :
gateway.h
golioth_get_block_cb_fn :
client.h
golioth_get_cb_fn :
client.h
golioth_int_setting_cb :
settings.h
golioth_lightdb_delete() :
lightdb_state.h
golioth_lightdb_get() :
lightdb_state.h
golioth_lightdb_observe() :
lightdb_state.h
golioth_lightdb_set() :
lightdb_state.h
golioth_lightdb_set_bool() :
lightdb_state.h
golioth_lightdb_set_float() :
lightdb_state.h
golioth_lightdb_set_int() :
lightdb_state.h
golioth_lightdb_set_string() :
lightdb_state.h
golioth_log_debug() :
log.h
golioth_log_error() :
log.h
golioth_log_info() :
log.h
golioth_log_warn() :
log.h
golioth_net_info_cellular_append() :
cellular.h
golioth_net_info_create() :
net_info.h
golioth_net_info_destroy() :
net_info.h
golioth_net_info_finish() :
net_info.h
golioth_net_info_get_buf() :
net_info.h
golioth_net_info_get_buf_len() :
net_info.h
golioth_net_info_wifi_append() :
wifi.h
golioth_ota_blockwise_manifest() :
ota.h
GOLIOTH_OTA_COMPONENT_BIN_HASH_LEN :
ota.h
GOLIOTH_OTA_COMPONENT_HEX_HASH_LEN :
ota.h
golioth_ota_download_component() :
ota.h
golioth_ota_find_component() :
ota.h
golioth_ota_get_manifest() :
ota.h
golioth_ota_get_state() :
ota.h
golioth_ota_manifest_subscribe() :
ota.h
GOLIOTH_OTA_MAX_COMPONENT_URI_LEN :
ota.h
golioth_ota_payload_as_manifest() :
ota.h
golioth_ota_reason :
ota.h
GOLIOTH_OTA_REASON_AWAIT_RETRY :
ota.h
GOLIOTH_OTA_REASON_CONNECTION_LOST :
ota.h
GOLIOTH_OTA_REASON_FIRMWARE_UPDATE_FAILED :
ota.h
GOLIOTH_OTA_REASON_FIRMWARE_UPDATED_SUCCESSFULLY :
ota.h
GOLIOTH_OTA_REASON_INTEGRITY_CHECK_FAILURE :
ota.h
GOLIOTH_OTA_REASON_INVALID_URI :
ota.h
GOLIOTH_OTA_REASON_IO :
ota.h
GOLIOTH_OTA_REASON_NOT_ENOUGH_FLASH_MEMORY :
ota.h
GOLIOTH_OTA_REASON_OUT_OF_RAM :
ota.h
GOLIOTH_OTA_REASON_READY :
ota.h
GOLIOTH_OTA_REASON_UNSUPPORTED_PACKAGE_TYPE :
ota.h
GOLIOTH_OTA_REASON_UNSUPPORTED_PROTOCOL :
ota.h
golioth_ota_report_state() :
ota.h
golioth_ota_size_to_nblocks() :
ota.h
golioth_ota_state :
ota.h
GOLIOTH_OTA_STATE_DOWNLOADED :
ota.h
GOLIOTH_OTA_STATE_DOWNLOADING :
ota.h
GOLIOTH_OTA_STATE_IDLE :
ota.h
GOLIOTH_OTA_STATE_UPDATING :
ota.h
GOLIOTH_OVERRIDE_LIBCOAP_LOG_HANDLER :
config.h
golioth_payload_as_bool() :
payload_utils.h
golioth_payload_as_float() :
payload_utils.h
golioth_payload_as_int() :
payload_utils.h
golioth_payload_is_null() :
payload_utils.h
golioth_pki_issue_cert() :
pki.h
golioth_post_cb_fn :
client.h
GOLIOTH_RPC_ABORTED :
rpc.h
GOLIOTH_RPC_ALREADYEXISTS :
rpc.h
GOLIOTH_RPC_CANCELED :
rpc.h
golioth_rpc_cb_fn :
rpc.h
GOLIOTH_RPC_DATA_LOSS :
rpc.h
GOLIOTH_RPC_DEADLINE_EXCEEDED :
rpc.h
golioth_rpc_deinit() :
rpc.h
GOLIOTH_RPC_FAILED_PRECONDITION :
rpc.h
golioth_rpc_init() :
rpc.h
GOLIOTH_RPC_INTERNAL :
rpc.h
GOLIOTH_RPC_INVALID_ARGUMENT :
rpc.h
GOLIOTH_RPC_NOT_FOUND :
rpc.h
GOLIOTH_RPC_OK :
rpc.h
GOLIOTH_RPC_OUT_OF_RANGE :
rpc.h
GOLIOTH_RPC_PERMISSION_DENIED :
rpc.h
golioth_rpc_register() :
rpc.h
GOLIOTH_RPC_RESOURCE_EXHAUSTED :
rpc.h
golioth_rpc_status :
rpc.h
GOLIOTH_RPC_UNAUTHENTICATED :
rpc.h
GOLIOTH_RPC_UNAVAILABLE :
rpc.h
GOLIOTH_RPC_UNIMPLEMENTED :
rpc.h
GOLIOTH_RPC_UNKNOWN :
rpc.h
golioth_set_block_cb_fn :
client.h
golioth_set_cb_fn :
client.h
golioth_settings_deinit() :
settings.h
GOLIOTH_SETTINGS_GENERAL_ERROR :
settings.h
golioth_settings_init() :
settings.h
GOLIOTH_SETTINGS_KEY_NOT_RECOGNIZED :
settings.h
GOLIOTH_SETTINGS_KEY_NOT_VALID :
settings.h
golioth_settings_register_bool() :
settings.h
golioth_settings_register_float() :
settings.h
golioth_settings_register_int() :
settings.h
golioth_settings_register_int_with_range() :
settings.h
golioth_settings_register_string() :
settings.h
golioth_settings_status :
settings.h
GOLIOTH_SETTINGS_SUCCESS :
settings.h
GOLIOTH_SETTINGS_VALUE_FORMAT_NOT_VALID :
settings.h
GOLIOTH_SETTINGS_VALUE_OUTSIDE_RANGE :
settings.h
GOLIOTH_SETTINGS_VALUE_STRING_TOO_LONG :
settings.h
golioth_settings_value_type :
settings.h
GOLIOTH_SETTINGS_VALUE_TYPE_BOOL :
settings.h
GOLIOTH_SETTINGS_VALUE_TYPE_FLOAT :
settings.h
GOLIOTH_SETTINGS_VALUE_TYPE_INT :
settings.h
GOLIOTH_SETTINGS_VALUE_TYPE_STRING :
settings.h
GOLIOTH_SETTINGS_VALUE_TYPE_UNKNOWN :
settings.h
golioth_status :
golioth_status.h
GOLIOTH_STATUS_RETURN_IF_ERROR :
golioth_status.h
golioth_status_to_str() :
golioth_status.h
golioth_stream_blockwise_finish() :
stream.h
golioth_stream_blockwise_set_block() :
stream.h
golioth_stream_blockwise_start() :
stream.h
golioth_stream_set() :
stream.h
golioth_stream_set_blockwise_sync() :
stream.h
golioth_string_setting_cb :
settings.h
golioth_sys_client_connected() :
golioth_sys.h
golioth_sys_client_disconnected() :
golioth_sys.h
golioth_sys_free :
golioth_sys.h
golioth_sys_hex2bin() :
golioth_sys.h
golioth_sys_malloc :
golioth_sys.h
golioth_sys_msleep() :
golioth_sys.h
golioth_sys_mutex_create() :
golioth_sys.h
golioth_sys_mutex_destroy() :
golioth_sys.h
golioth_sys_mutex_lock() :
golioth_sys.h
golioth_sys_mutex_t :
golioth_sys.h
golioth_sys_mutex_unlock() :
golioth_sys.h
golioth_sys_now_ms() :
golioth_sys.h
golioth_sys_rand :
golioth_sys.h
golioth_sys_sem_create() :
golioth_sys.h
golioth_sys_sem_destroy() :
golioth_sys.h
golioth_sys_sem_get_fd() :
golioth_sys.h
golioth_sys_sem_give() :
golioth_sys.h
golioth_sys_sem_t :
golioth_sys.h
golioth_sys_sem_take() :
golioth_sys.h
golioth_sys_sha256_create() :
golioth_sys.h
golioth_sys_sha256_destroy() :
golioth_sys.h
golioth_sys_sha256_finish() :
golioth_sys.h
golioth_sys_sha256_t :
golioth_sys.h
golioth_sys_sha256_update() :
golioth_sys.h
golioth_sys_srand :
golioth_sys.h
golioth_sys_thread_create() :
golioth_sys.h
golioth_sys_thread_destroy() :
golioth_sys.h
golioth_sys_thread_fn_t :
golioth_sys.h
golioth_sys_thread_t :
golioth_sys.h
golioth_sys_timer_create() :
golioth_sys.h
golioth_sys_timer_destroy() :
golioth_sys.h
golioth_sys_timer_fn_t :
golioth_sys.h
golioth_sys_timer_reset() :
golioth_sys.h
golioth_sys_timer_start() :
golioth_sys.h
golioth_sys_timer_t :
golioth_sys.h
GOLIOTH_SYS_WAIT_FOREVER :
golioth_sys.h
GOLIOTH_TLS_AUTH_TYPE_PKI :
client.h
GOLIOTH_TLS_AUTH_TYPE_PSK :
client.h
GOLIOTH_TLS_AUTH_TYPE_TAG :
client.h
Generated on Tue Nov 17 2026 16:24:43 for Golioth Firmware SDK by
1.10.0
